ATTN: iOS Users with issues after updating to iOS 13
I Am Having Issues with My Garmin Watch After Updating to iOS 13 on My iPhone
With the released of iOS 13, some changes in the way that your Garmin device communicates with your phone have changed.  Review the following symptoms which should solve your issue.
The Garmin Connect app displays the message "Bluetooth is turned off"
iOS 13 requires Bluetooth Sharing to be turned on for the Garmin Connect app.  Below are steps to enable this setting.
  1. From the iPhone, select Settings
  2. Scroll down and select Connect
  3. Toggle Bluetooth Sharing on
NOTE: For the best user experience with your Garmin device and your phone, the Location setting should be set to Always and all toggles should be set to on.
I Am No Longer Getting Smart Notifications on My Garmin Device
To correct this issue follow the steps below:
Check Bluetooth Settings
  2. Select Bluetooth
  3. Under MY DEVICES select the i icon next to your Garmin device
  4. Toggle Share System Notifications to on
Check Notification Settings
  1. Select Notifications
  2. Set "Show Previews" to Always
  3. Under "NOTIFICATION STYLE" select Messages
  4. Under "OPTIONS" set "Show Previews" to Always (Default)
Update your phone to iOS 13.3.1
Why Do I Need to Keep Signing Into the Garmin Connect App on My Phone?
Garmin is aware of an issue where the Garmin Connect app requires you to sign in when you open the app on an Apple phone.  This can occur when:
  • The phone is rebooted
  • The battery on the phone runs out of charge
  • Some reports of the issue randomly occurring
Apple has released a software update for your phone that corrects this issue. To download and install  OS 13.3.1, refer to the following Apple instructions: Update your iPhone, IPad, or iPod Touch
    0 Former Member over 5 years ago
    After installing iOs 13.1.2 everytime i make a call my fenix5 plus vibrates and show that im calling someone. How do i turn this feature off??
    I’m on iOS 13.1.2 and Connect isn’t completely working with my Vivasmart HR+. Eg isn’t showing my sleep time even after syncing. Also no longer sending run info to my Nike Run Club app despite verifying they are set to share info and have worked fine for a couple years.
    None of these suggestions help. My phone still Ian able to connect with my garmin device since I updated to iOS 13.2.
  • I am having the same issue. Get past the confirm passcode. Not able to sync activities. Running iOS 13.1.2 and Garmin Connect 4.23.3.4.
    0 Former Member over 5 years ago in reply to Former Member
    Same here and this morning I had a message to select for help and when I did that the message disappeared from my phone.  I need to get these messages as I don't have the phone ringer on in my classroom and this is how I know if I have an important message.
    Helaas alles staat ingesteld als omschreven. Maar ik krijg geen berichten op mijn horloge
    This is driving me nuts too!!  Cant figure out how to turn it off.  Also now my battery only latsts abour 24 hours when it used to last about 3 days!
    0 Former Member over 5 years ago in reply to 9861848
    I’m having almost the same: I get all notifications except whats app notifications.
    how I fix this? I’ve tried all tips that Garmin suggested to do...
    0 Former Member over 5 years ago in reply to Garmin-Blake
    By changing these settings it is compromising my privacy!?
    I feel like this may be an issue with all messaging apps. I am not getting notifications of texts coming in from Google Voice when notifications are set at Never show preview.
