Edge 530 with iPhone 11/iOS 13 not pairing
Edge 530 not pairing with iOS 13 on iPhone 11 Pro. Process starts by asking to verify pairing code then the running man is seen for a while. A message then appears saying something went wrong. It asks to try again. Have powered down both units. Have removed paired device. Have turned off/on Bluetooth.
    I’m having the same problem with my Fenix 5. Have tried restarting, updating the app, unpairing but still unable to connect.
  • Same here with Edge 830. Tried restarting, removing Garmin connect app. Remove it from BT settings...
    I have no problems with my 935.
  • ditto.  Edge 830 won't pair to my iPhone 11 Pro running iOS13.  Forerunner 935 and Edge 810 work fine.
  • I can't help, but I can confim that I have exactly the same issue and the exact same devices (Edge 530 + iPhone 11 PRO ). Waiting for iOS 13.1, should be released today to fix this issue.
  • I had the same issue, but finally after a number of tries, it worked. I also turned off Wi-Fi on both and turned it back on, it was after that that it finally worked. I had removed the 530 from the Garmin app on my new iPhone and removed the iPhone entry from the 530. Also, I made sure that I initiated the pairing in Garmin Connect, previous tries I had gone into the iPhone BT settings and paired one of the two BT 530 entries and that seemed to be part of the issue. Once I went in strictly via the Garmin Connect app, it worked on the next try. Good luck, I was about ready to give up on mine till it finally worked.
  • Thanks for your reply.  Still no  luck. I had similar problems before (< io13) with 2 830 devices in my BT settings...
    Question.. did you have the issue also on ios13?
  • I had a similar issue on iOS 12 after the 530 firmware upgrade to 4.10. This most recent pairing problem was after upgrading from an iPhone 8 to iPhone 11. The iPhone 8 had been upgraded to iOS 13 and I didn't have any BT issues. It was when I tried pairing to the iPhone 11 w/iOS13 that I must have tried the pairing at least a dozen times till I was finally successful.
  • As a follow up, on iOS 13.1 there is no change, I still can‘t pair my devices
  • I can't pair my Edge 530 with Garmin Connect on an iphone 11 with 13.1 - constantly get error messages after getting past the code page.
