I had this problem and fixed it. The issue is probably that the .fit file is corrupt/damaged. Plug your watch into your computer and open the drive, then go to activities and find the activity in question…
Metrics like steps were loading but activities were not. I also could upload the files manually so they weren't corrupted. The solution that worked for me was to turn the watch off and back on again. After…
Exact situation and they try to make it sound rare I have a one plus phone.
I am also having trouble fixing a corrupt .fit file. Would you mind taking a look to see if you can fix it? I would really appreciate any help you can offer. [link deleted]
I created a .zip file to upload to this site, but when I went to the "insert" option, there was no option for me to upload a file (?). I hope the link I have provided above works.
In response to my own post, I used fitfiletools and successfully opened the file. The problem, though, continued: when I tried to manually upload the file to Garmin Connect, I got the same error as before: "
"An error occurred with your upload. Please try again." |
Any help to address this so I can upload the file would be much appreciated.
I can't get the file into Garmin via normal bluetooth syncing with my phone, and I cannot manually upload it--I keep getting the error code "An error occurred with your upload. Please try again."
Any ideas what I can do to get past this error since it seems like the file isn't corrupt?
Well you were spot on. I kept trying to upload the activity, kept getting the error, and then magically the upload worked. The only think I did was keep trying. Go figure. Anyway, I really appreciate your taking a look and giving me your guidance.
so disappointed.
this morning after my daily run, i've tried to sync my garmin fenix. And it was during the outage of 22/09.
i've plugged my watch on my computer, navigating into ../Library/Application Support/Garmin/Express/RegistedDevices/xxx/PendingSyncUploads/Garmin/Activity .. and the folder is totally empty. (oc my activity is only available on my watch)
is there a way to force my watch to put an activity to this folder? (unless if Garmin's outage has broken some activities server-side - which is totally possible - and which could be fixed by Garmin team)
Yes it tooks a part of my night to do it.
But it's alright now.
I used Android File Transfer on my Mac. Navigated into ACTIVITY directory and find the fit file with the date corresponding to my activity.
on the Garmin Connect Web App - Side, i uploaded the file, and voilà !
