I had this problem and fixed it. The issue is probably that the .fit file is corrupt/damaged. Plug your watch into your computer and open the drive, then go to activities and find the activity in question…
Metrics like steps were loading but activities were not. I also could upload the files manually so they weren't corrupted. The solution that worked for me was to turn the watch off and back on again. After…
Exact situation and they try to make it sound rare I have a one plus phone.
I had this problem and fixed it. The issue is probably that the .fit file is corrupt/damaged. Plug your watch into your computer and open the drive, then go to activities and find the activity in question. Download it to your computer and try uploading it to Garmin directly. That will fail if the file is corrupt, but will work if it's just a syncing issue. If the file is corrupt, go to http://garmin.kiesewetter.nl/ and upload the damaged file there. Then convert to autofix.fit file and save that download to your computer. Then upload that file to Garmin and it should show up fine.
Metrics like steps were loading but activities were not. I also could upload the files manually so they weren't corrupted. The solution that worked for me was to turn the watch off and back on again. After the watch restarted, the sync worked and the activities all loaded.
I'm having this exact problem and Garmin cannot seem to fix it. Everything is up to date, a daily activities will not appear. I also can't go to activities and see any activities. I'm wanting to buy a new Garmin watch so I hope this is going to get fixed
7550831, if you get any message other than Import Complete, then there is a problem with the file being corrupt. Attach it to this thread. We can look to see if it is repairable.
