I’m facing the same issue. The Connect app runs and drains battery in background for many hours a day. Two days ago it peaked at 55% of battery draining during background activities.
I denied Bluetooth…
I have had the same issue on iOS since January. Prior to that the Connect app had been working fine for a couple of years. I spoke to Garmin customer support today and sent them a diagnostic from the Connect…
I chatted with Garmin Support just now. Here is what they recommended:
Backgroupnd App Refresh: Off
Force close app when not using
I see the same issue with GCM draining my iPhone battery at an extremely quick rate. It is at its worse when using my Garmin edge 520 and slightly less although still very fast when using my new Fenix 5 plus. I am sure something has changed with an update as I have owned the Edge 520 for a couple of years and the issues only started a few months back. At first I didn’t link the two together until I got my Fenix 5 plus and it started draining the battery at an accelerated rate also.
Seriously considering returning the Fenix 5 and getting a Suunto 9 as I can’t live with my phone having the battery drained in 6 hours vs the 18 hours I get when the watch is not connected and I never had this sort of issue with my Sunnto Ambit.
Hi,
I know they're an already a couple of threads with this problem but they are mainly based on older iOS and App versions.
Since updating my 12 Pro Max to iOS 16.4 I have a major background battery drain from the connect app. Which basically forced me to manually close the connect app after every opening.
I can't rule out if its related to the iOS update or due to an update of the app.
I recently had my battery replaced in the Apple Store so it's definitely not due to some weak battery. The app managed to drain 50% of a brand new battery in just a couple of hours overnight. So there wasn't any activity started on the app which could get stuck syncing. And unfortunately this is not a one-time event.
Anyone else experiencing similar issues?
I denied Bluetooth permissions, I sync my Fenix over Wi-Fi too, in an attempt to see if that improves the situation
