*FIXED: Weather Report Unavailable
*UPDATE: Garmin Connect Mobile v2.0.2 (Released on 3/19/14 for Android) is now available for download on the Google Play marketplace. The Weather Report issue has been addressed in this update and should be fixed. If you continue experiencing issues with this, please try the following troubleshooting steps:
  • Ensure that you're running the latest version of Garmin Connect Mobile.
  • Ensure that you're running the latest software version on your Edge device using Garmin Express.
  • Ensure that you have the latest version of Android OS installed on your device.
  • Ensure that Weather is 'On' from within the Garmin Connect Mobile app. (To do this, connect the Edge to the GCM Application via Bluetooth. Once connected, Tap on Menu > Devices > Details (under the connected Edge device) > Settings > Toggle Weather to 'Yes'. Be sure to return to the Home screen to implement this change.)
  • If Weather is still unavailable, Turn Bluetooth Off/On and Repair the connection between the Android and Edge devices.
  • If Weather is still unavailable, Power Off/On both the Android and Edge devices and Repair the Bluetooth connection.
Please let us know if you continue experiencing Weather Report issues after all troubleshooting attempts have been made. Thank you for your feedback!
We are currently aware of an issue causing users to be unable to view weather information on their Edge device when paired to the Garmin Connect Mobile application via Bluetooth. This issue has been reported to our developers and should be corrected with the next update (version 2.0.2, ETA Unknown). This thread will be updated once this update is released.
We appreciate your feedback and apologize for any inconvenience that this may have caused.
  • @DNIGHTRANGER
    I turned the weather off, restarted the app and turned the weather on. And it worked... But I have to do that every time I launch my Garmin.
    Thanks for your help :)
  • Hello,
    It seems to be a conflict between weather and livetrack: when i have the weather reaport, the live track don't work (it shuts down)...
    Garmin, please FIX the weather BUG!!!!
    Bonjour,
    Le 07/04/2014? toujours pas de météo sur mon Garmin 810, malgré les mises à jour....
  • Yawn....
    Edge 810 on current firmware.. Nexus 5 with the current Garmin App..
    Weather worked once...
    I am about to give up, sell this hunk of junk and find another cycling computer..
    Come on Garmin, it can't really be that hard to get something so simple to just work can it?
    Weather still not working
    Yawn....
    I am having the same problem the weather is not working and if I turn it off and on in the app it works but live track stops my 810 work great till the last two update now it's broken I hope you fix this problem soon
  • I am having the same problem the weather is not working and if I turn it off and on in the app it works but live track stops my 810 work great till the last two update now it's broken I hope you fix this problem soon
    Unfortunately, Garmin has marked this thread as 'Fixed' and they have not responded since they claimed the issue was fixed..
    I am about to just give up.. I purchased the bundle version @ $700 plus tax and they (read: Garmin) can't be bothered to fix the issues... To make matters even worse, they can't be bothered to even respond..
    Sad, really sad..
    Updated gcm 2.0.3 but the wx report worked only once and since then nothing, tried to hard reste the 810 but no success; i think it' stime to improvement this feature with BETTER and more reliable wx server like accuweather, isn't it?
    Hi.. the weather updates on my edge 510 still not ok after installing connect 2.0.3. I'm using samsung note 2 w latest android version. Please help
  • The weather updates on my edge 810 still NOT working, on 2.0.3 too NOT working. Tried everything above as steps. Only once the weather showed and after that it is unavailable. Garmin, please, fix this at last!
