Please include a change description in Google Play Store when you release a new version of Garmin Connect Mobile!
Please add a “total weight lost” feature. I would like to track how much I have lost since setting my goal. Even how much weight to go to get to my goal. Right now it isn’t easy to read how much I’ve lost…
Not improvement exactly in the Garmin Connect Mobile app itself but how about adding a sticky post on this Garmin Forum area with the latest version of the app in title and bullet point listing what has…
It would be nice to see the currently installed software versions too (firmware, sensor hub, CIQ...
Not sure whether it is available for all Garmin models, but I can view that info in GCM » device » Settings » System » About. Not as quick as with a long tap, but the info is there, in case you did not know about it.
What do you get when you tap directly on the icon of the watch at the top of the My Day screen? You should get the properties of the device, including the settings. I use both Android and iOS. Right now I cannot test it on the Android, but the access to the device settings was identical to iOS.
Nope does not work that way on Android..Takes you to settings thats correct. if you press and hold on watch it gives Product names , unit id, hardware address last connected, then canel, remove device and sync... NOTHING else
I have gone through every menu and pressed and held on every icon and there is NO about screen for the watch on android... SO you android claim is incorrect
