TDA 4.63.1.52816 Feedback and issues
I installed this version and still didn't receive any suggested daily workout. I assume that it would be on my Dashboard, but I also looked in the Workouts section and still didn't see anything.
I think I have identified a glitch in the Climb Widget
On my first ride after installing this update, I noticed that the number fields were stuck showing Ascent remaining, Average incline and ETA, normally, they would alternately show Distance remaining, Max incline and Elapsed time.
I ended my ride, then had a look at Settings, where I found the option to configure the Climb Widget. It was at "Dynamic", so I changed this to "Static" and did another ride.
This time, the fields were alternating as usual, except (of course) the Max incline number was stuck showing the maximum on the whole climb rather than the maximum of the remaining climb.
I ended this ride, went back into Settings again, and changed the view to "Dynamic" again.
On my next ride, the Widget was behaving as it should, showing all six data fields, alternating, and only the Max ascent remaining.
It looks like some variable perhaps needs to be set with a default value??
