Since the latest beta version i seem to be in erg mode when in TDA. Problem doesn't exist in Rouvy.
Problem appeared after fresh install of windows 11 and latest beta
Saw your other post. I do not have this problem, but I have a Neo2T running on W10, so my situation is not comparable to yours. Not sure when, if ever, I will have W11 as my PC's are not W11 compliant.
Solution is to keep it at ant+it doesn't work a lot BT
BTW for the Dev team, it's "solved" forcing TDA to communicate via ANT+ with the NEO. The same issue still exists if i change to BT (Original low serial NEO)
