1.25.0.6523 Flux2 Smart Calibration Only Works with ANT+, Not BT
I tried the new calibration function today for my Flux2 Smart.  There wasn't any guidance or instructions.  I first noticed a calibration button before starting a ride.  However, when I selected calibrate, an explanation window popped up with a calibration button.  After pressing it, nothing happened and the BT connection to the trainer was lost.  I did a ride after reconnecting.  At the end, I went to the device page and tried to calibrate again.  Had the same result with BT connection lost.  After that, I connected an ANT+ antenna, disconnected the BT transmitter, connected to the Flux2 Smart using ANT+.  After doing that, I was able to successfully calibrate.
Not sure if calibration is supposed to work with BT or only ANT+, but currently it is not working for me with BT.
