Vivosport - Turn off bluetooth disconnect / connect notification
Hi,
I must be missing the obvious but how do I switch off the incessant blue tooth connect disconnect notification on a vivosport. Only appeared after the most recent update.
I don't want to switch off the bluetooth connection, I just don't need a notification from vivosport each time I move away from my smartphone as the bluetooth connection drops out.
Thanks
    0 Former Member over 5 years ago
    Had my Vivosport 2 months and like you this happens each time I move in and out of range of my phone with the sound and vibrate. I'm thinking of turning off bluetooth until i need to updatexat the end of the day.
    Do your intensity minutes work correctly?
    +2 Former Member over 5 years ago
    From My Day tap menu top left. Find Garmin devices and tap Vivosport. Tap Device settings. Look for Nitifications and alerts. Tap to untick Alerts, bluetooth conbection.
    0 Former Member over 5 years ago in reply to Former Member
    Thanks this worked.
    No but this is not a precision device. I use it as a rough guide for the most part.
  • Thank you for this post and the responses, I must have set this by mistake and could not find where to turn it off, I had to remove my device at night because I don’t have my phone by my bed and it kept buzzing me it is like Chinese drip torture.
