I have a Vivosport now since 8 months. On the watch in display light setting, you can choose: brightness, time-out, movement. On movement I choose always "Only Activity". After a while, something is changing this into "Always On". Really annoying as I don't want to going on and of the display when I move my arm. I use as daily monitoring steps, heart rate, ... not for activity tracking . What do I wrong?
Thanks tmk2! I didn't know this was also a setting in Connect. Still strange that when you have the possibility to change it on the watch, the change is not synced back to you Connect account. I have changed it in connect now and I hope it stays like this. Probably it will.
Yes, if needed it will tak a look into the device settings the mobile app also. Changing in connect worked for me. Now the settings on the watch are the correct one and doesn't change back anymore... ;-)... Topic can be closed.
