vivosmart 4 no longer tracking distance and pace in walking activity
My vivosmart 4 track my walking activity, however it does not track the distance or pace. I reset the watch and still does not work. I am using an Iphone 8 ios 14. My gps is on. Why does vivosmart 4 no longer track distance?
  • Hello! Can we double check these settings?
    1. Open the Garmin Connect app
    2. Select More (lower right)
    3. Select Settings
    4. Select Phone Permissions
    5. Select Manage Permissions
    6. Select Location in the iOS settings
    7. Select Always to enable Garmin Connect to access your phone’s location
    8. Toggle Precise Location to on.
    9. Navigate back to App Permissions and make sure your Location status is set to On
    NOTE: In addition, Cellular Data permission must be granted to use Connected GPS.  By default this permission is enabled however if you turn the setting off, Connected GPS will not work.  You can check this phone setting under Settings>Cellular then scroll down to the Connect app under CELLULAR DATA.
