I accidentally discarded an activity instead of saving it - Now The activity is not important but I am curious if there is a way to get it back?
Zip the fit file and attach it to your post. We can see if it is possible to at least partially fix it.
Several errors:
timestamps not in chronological order
unexpected big change of distance value
unexpected big change of altitude value
very long break time (273346 hours)
distance values not in ascending o…
is there any way it would be possible to help me with the same issue?
Megan-Grace, this will work - _3U82018-fixed.fit
Repaired using Fit File Repair Tool. Import into Garmin Connect using…
Please could you help me as well, I had the same problem. Accidentally discarded my run, don’t know how that happened.
regards,
idwer
_3795546.zip Here you are. Thank you
Several errors:
distance values not in ascending order
Fixed by Fit File Repair Tool.
Unzip the file then import into Garmin Connect using the [import data page]
Done! You are the best! Thank you!!!!
is there any way it would be possible to help me with the same issue? I managed to recover the fit file from Recuva, but in trying to import it to garmin connect on the webpage, it says that the file type i'm trying to import is not supported (even though it is a fit file). I'm so upset that this run is gone and would REALLY appreciate any help!
here is the file zipped, I think it is the right one as it was the only file recovered with the date of the run (today) and within the path said "activity"
Repaired using Fit File Repair Tool. Import into Garmin Connect using the [import data page]
