Running Display time and speed
Any chacne of an update that allows yo to change what is displayed while running, Ideally I would like to see speed, time and distance. Heart rate is not something I look at while running so to not have the option to change that, also I cant see total distance run anywhere? if I want to turn around at 3.5km I don't know where that is.
  • Hello! You can edit the data field by doing the following:
    1. From the settings menu in the Garmin ConnectTm app, select Garmin Devices.
    2. Select your device.
    3. Select Activity Options.
    4. Select an activity.
    5. Select Data Fields.
    6. Select a data field to change it.
    0 Former Member over 4 years ago in reply to Garmin-AmberD
    Thanks yes I know but you can only change the bottom field, the top is locked to heart rate. so if I want to campare current pace to average pace for examplie I have to scroll through while im running. I would like the option to choose what the top display is like distance, time, pace etc. obvioulsy it would be fixed and set in the app but it would be a useful feature.
    you get an aprox heart rate with the watch hands anyway
