Hi guys,
Hi guys,
Thanks.
So I have successfully managed to add the HR to apps that support HR broadcast.
I have used a Samsung S10 which has a ANT+ sensor built-in.
I had also found an old Adidas miCoach ANT+ USB receiver, and when plugged in to a Huawei P30 Pro, I could also see there the HR.
Unfortunately apps like Strava have removed the ability to connect to HR sensors.
I guess the best solution (less worst) at the moment is to use apps which have workout plans with voice alerts (mainly for interval trainings), and use them either with the ANT+ sensor, or without, and then rely to the data upload and sync from backend from Garmin Connect (obviously I will have to also start an activity on the watch).
I know Runkeeper may do that. Any other app?
I really do not understand how Garmin Connect is not also a stand-alone app: it can create workouts on the app, but you cannot start them from the app itself (am I right or wrong?) and since I do not have a compatible watch, the functionality to create workouts is useless. Any suggestion?
