i cannot find if there is a way to know how many percent is left on the battery. It looks like it is not available on the app. on the watch, i can see a gage but not a percent. Advice ?
You can find the percentage on the watch. But it takes several steps: swipe left to unlock screen - long press - swipe to settings (gear symbol) and tap - swipe to wrench symbol and tap - swipe to About and tap. Now you see the battery percentage and the software version.
Indeed but there is a way...Appreciate that. Do you know on how low the battery can go with all the function working ? If it gets too low, does the hands stop moving ?
In garmin connect under display options / visible widgets on the watch settings ,make sure the Time and Date one is turned on. Then that will be the first left swipe and will show the date, time and battery.
Correct. But this only displays a battery gauge symbol and not the actual percentage.
