Battery lasts only for 2-4 months. Changed already second set in 5 months...
What could be the problem?
    I have the same issue although my second set lasted only 2 weeks. When i replaced the batteries (with the recommended type $10!), i noticed there had been water inside.
    I used some dielectric grease on the gasket to prevent more ingress. This time, i see no moisture.
    There are numerous complaints in the forum of water incursion. Garmin does not answer questions here. you may need to contact them for a replacement.
