Music Garmin vivoactive 3. The vibration signal stopped working. The vibration motor itself vibrates when turned on. I tried to remove the do not disturb mode in different versions - it does not help. Rebooted, reset to factory settings. I changed the firmware from 6.0 to 5.9. Then I put the last 6.0 again - nothing helps. I tried everything, unchecked the do not disturb checkbox. They don't vibrate. They do not vibrate, even if I choose the vibration strength - weak, medium, strong. They do not vibrate. They do not vibrate when I turn on the sport mode. Doesn't vibrate when notifications arrive. They only vibrate when they are turned off and I turn them on. This is likely a hardware or software error. Advise what to do?
