- My vivoactive 3 has turned the calibrate on with the treadmill setting. It is giving me all the wrong readings. I want to switch the calibrate off how do I do that?
You need to do a treadmill activity of at least 1.5 KMs or 1 mile. When you stop the activity, you should see the option to save or 3 dots. If you press the 3 dots, the calibrate option should appear.
Some people have reported that the calibrate option disappeared with the latest update but others have said it's still there.
