Vibration and Incoming call [problem] VA3M
Hello,
Bought my VA3M a month ago. Just recently started using it as a day to day watch. I've got two major problems with it:
1) Vibrations - they don't work at all. I've used every single possibile setting in the watch and phone settings/app and it doesn't work at all. The one and only time it works it's when im disconnecting the watch from PC (Garmin EXPRESS);
2) Contact data for incomming calls. That's the next thing that bothers me. When I'm receiving a call it shows a number instead of contacts name (eg. +52 223 21 15 instead of Anna Smith and yes i've got this number in my phones adress book and i've added this app (Contacts) on the garmin app as the one that can give notifications). The worst part is that if I wont pick up the call I'll get a message about missed call and in this notification theres the contact name "Anna Smith" as it should be. Someone?
Watch is great but those two thing makes in a little annoying to use in a day to day scenario.
    0 Former Member over 5 years ago
    1) Keep Garmin Connect open in the background in the phone all the time.
    2) Check if you gave Garmin Connect permission to read your phone's contacts.
    0 Former Member over 5 years ago in reply to Former Member
    One problem solved. I am using Galaxy s8 and i gave all permissions to the Garmin App on the phone but when i went to the permission tab on the phone there is an extra permission about  "app running idle". After checking this box contact data appear on the watch : - )
    Unfortunately the vibration problem still occurs.
