I thought my va3 music was broken as doing the stairmaster heart rate registered 92bpm, wearing a heartrate strap and taking heart rate readings off the stairmaster was giving me 180bpm. sent mine back…
I have a new va4 and it's totally of the charts inaccurate for me. When I just wear it normally, the hr is fine. As soon as I set it to cardio, it doubles my hr and suddenly I go from 80-100 bpm just walking…
When I have my setting set to cardio and I walk around the block, my heart rate shows 160-170. When I continue around the block and change the activity to running, my heart rate drops down to 140's. I don't understand this differentiation. Can Garmin comment on this please? I loved my fitbit, but I love my fenix6 too I just wish it would work better.
This bugged me so much! Using cardio profile, wrist based heart rate is about +30 bpm more than it should be. Seeing as my run and cycle isn't too inaccurate compared to my HRM strap, it must be the profile. So this eve I created a new profile, called HIIT, added the same data screens as cardio, except I put heart rate guage instead of just heart rate. Bingo, works much better!
So solution is to create your own profile for any in built profiles that aren't accurate.
I'm using fr945 btw
I actually found this new profile just as bad as original, but under reading my hr! I've since been advised to wear my watch further up my arm, a lot further up than the wrist. I also wear it on my right arm as apparently its better on your thicker arm. Basically keeping it away from the bone. This method has been working brilliantly for the last 5 weeks now. So no need to create new profile or change any settings on watch.
Another thing to try out for anyone having these problems when walking is bend your arm at 90 degrees and hold it like that for a minute or two and see if the HR catches up. Sometimes when i put my arms down my veins popup and I feel them being filled with more blood, I assume that could make it harder for the sensor to determine the HR.
This method has worked for me for the couple times i've tried it so far.
Regarding strength or other activities, where you heavily use hands - of course it will not be accurate as you're flexing arm muscles, so no fix there.
Depends on what you are relying on it for. To be honest I have had several different heart rate bands over the years and I would never rely on one for accurate heart rate readings.
I bought a Magene strap and on the cross trainer it works consistently. The watch gave me just good results one out of 5, so I go for consistency. Using a wrist sensor probably works for outdoor running, but indoor activities with hand action require a strap.
