I thought my va3 music was broken as doing the stairmaster heart rate registered 92bpm, wearing a heartrate strap and taking heart rate readings off the stairmaster was giving me 180bpm. sent mine back…
I have a new va4 and it's totally of the charts inaccurate for me. When I just wear it normally, the hr is fine. As soon as I set it to cardio, it doubles my hr and suddenly I go from 80-100 bpm just walking…
Happens here aswell. Yesterday I started working out without any excercise mode active and the heart rate was reacting rationally, until I turned strenght exercise on. After turning it on measured heart rate dropped from 90-130 to 70-90 and got stuck there for the next 20 minutes. Really frustrating..
Ever since the last update mine has been crazy inaccurate with cadio excercise. At one point the HR dropped to below 35bps and averaged around 90bps. This is a HIIT class and there is no way my heartrate was that low. I've since bought a HR chest strap and just using the optical for walking/hiking.
Me too first time i tried the cardio option yesterday. I have done Run and Strength and it looked fine so far. The cardio had me like at least 40HR higher than where it should, and it was stuck there... I removed the VA4 it stopped recording HR, wore it again on other hand and got the exactly same wrong measurements.
So it's not like it was stuck or something. It's something in the Cardio mode.
I just got my Garmin Vivoactive 3 and am also very frustrated with this issue of very inaccurate HR readings. Seems ok during mountain biking, but when I do a strength workout- it will read 43 bpm when I know my HR is at least 120 bpm. Very frustrating!! I just got this watch and now wishing I did not!
There are lots threads about the accuracy of wrist-based HRMs. You might want to check out this from the Garmin Support site: The Heart Rate Sensor on My Watch Is Not Accurate, especially where it mentions weight lifting.
"Activities that cause flexing of the wrist (ex. rowing, weight lifting, or gripping a tennis racket) may create an effect similar to wearing the watch too tightly and restrict blood flow. When this occurs the watch may have a difficult time detecting an accurate heart rate."
2 days ago my Vivosmart 4 started to register wrong HR values (way to high) in the middle of a very slow jogging. I had a small heart infarct less then 2 weeks ago and got a bit nervous... but checking my pulse I realise VS4 is way wrong. The HR has worked fine for a year- I was thinking it was due to blood thinning medicin, but is it the VS4!?
For me it is random, I tried some tips (wearing it loose, other wrist, etc etc) and some days it works correctly, other days it stays below 100. I also had one incident during walking where it stayed on 56 bpm. I am still trying to find a way to make it more reliable. My only point is, I had a cheap device before and even though it was not accurate, it was at least reproduceable in its behavior, where VA3M is definately not.
