Continuous HR monitoring with chest strap - non activity, is it possible?
I've had my vivoactive 3 for a few months after having issues with the Forerunner 235 and am loving it.
However, I am after continuous HR monitoring and am wondering if the chest strap would offer this function. I've installed my new garmin chest strap and synced it with my watch, however it seems I can only have it record HR data via the wrist monitoring when not in an activity.
Is there any way to have it use my chest strap for ordinary day to day, non-activity data? I've tried turning off the 'wrist HR" function but it won't pick up my chest strap data, unless I set it to an activity.
I exercise frequently however also use the device to keep an eye on my daily HR for health reasons which my cardiologist finds very useful.
Also, I read through some past threads and someone said that the vivoactive only records HR 4-5 times in an hour. This doesn't seem to make sense as when I look at my graphs it gives an average HR in a 2 minute period. Perhaps that thread was an older one and the watch has been updated to capture more HR data.
Cheers.
    not sure on the non-activity...
    but for the HR recording... there are 2 settings... smart and always on... or something similar.
    smart records every 4 secs... need to check the manual again...
    while the latter is self-explanatory.
    Do you mean the broadcast feature, as in If broadcast on it's continuous HR monitoring? I've tried having broadcast on but it still seems to capture HR data every 2 mins. Mind you I only discovered the broadcast feature today while searching these forums looking for an answer to the chest strap question, so maybe I'm not using it properly. I'd be keen to know how to get it to record every 4 seconds if possible, that'd be neat!
    ah damn, was talking about the settings for the built-in hrm... so ya ignore wat i said earlier :P
    Ha ha, all good! :) Hopefully someone may have an answer, at least with how to get the chest strap to work outside an activity like that the wrist monitor does.
  • Maybe you can make a activity named "daily routine" switch off gps and I think you can record your chest strap heart rate.
    and when you save it ons a regular base ,morning etc you can acces the data with garmin connect
    maybe one of the specialist here nows or this wil work .
    nico
  • I've had my vivoactive 3 for a few months after having issues with the Forerunner 235 and am loving it.
    Cheers.
    Just out of curiousity, if you take your watch off while paired with the chest HRM does the watch still report a HR?
    nico
    Yes I did something similar, set it to treadmill activity. Daily routine would be better as it wouldn't have a pre-set idea that I'm meant to be walking all the time. I didn't know you could turn off GPS, I'll look into how to do it. Thanks.
    No I tried this, if not set to an activity, and paired with the chest HRM it defaults to wrist HR. When you take it off it cuts out. I tried jumping up and down on the spot with the watch off just to make sure and it slowed down until it cut out all together. Did the same when I turned off wrist HR too.
  • You could use the default Cardio app.. it has gps turned off by default. You could reduce the data fields to choose only time, so that there is minimal battery loss. You can swipe it to the right & you will be back at watch face, use it as normal through rest of the day. I have seen the chest strap continue to track the heart rate monitor even without the watch on as long as chest strap is connected.
  • The vivoactive 3 is not designed to record 24/7 heart rate with an external sensor and will always use the optical sensor as long as it is turned on. The only workaround would be as other users have suggested, to record an activity with the GPS turned off to help extend the battery life.
