Hi,
Anyone else using the MilestonePod footpod? I have a few question when using this on a treadmill.
So first of all, the Milestone folks told me to set the footpod calibration factor to 100% in Garmin as the footpod has its own calibration within the footpod's own app, which I have used a couple of times to match the GPS distance when running outside. In any case, it is set to 100% inside Garmin.
Now when I run on my treadmill with the footpod connected, the displayed speed is very different from what the treadmill displays. I put this down to the treadmill being inaccurate. So at the end, before hitting Save, I did treadmill calibration to make the total distance match what the footpod claimed (from a separate syncing of the footpod with te footpod app, I did this before saving the Garmin activity). The footpod distance was much less than the treadmill one. The question is why, if the footpod was connected, shouldn't it be getting speed and distance from the footpod? With 100% footpod calibration, shouldn't speed and distance on the watch and the footpod app match by definition? So what did I achieve by doing "Treadmill Calibration"? The footpod calibration is still set to 100% . Does this mean the watch was using speed and distance from its internal accelermoeter instead of the footpod? Why? The cadence seems to match exactly that in the footpod app, so I don't think the footpod disconnected at any point in the activity.
Separate issue, doing the treadmill calibration fixed the distance in the activity in Garmin Connect, but the auto-sync to Strava still sent the original distance and speed.
Any help undertsanding this behavior would be appreciated.
Thanks.
