I updated my Venu to 6.10 yesterday morning and immediately lost the auto-scroll option from my running screen to see the various stats during my run. The option appears to have been removed completely. Has anyone else had this issue?
I would not call that a fix... Maybe a temporary workaround. The desired behaviour for the vast majority of users is as follows: have display turned off and when I raise my wrist, auto-scroll over data…
Garmin-ZacGarmin-AmberD can we get official statement on this problem? You guys can't tell me that desired functionality for autoscrolling is display always turned on. That will significantly reduce battery…
I have just spoken to Garmin and have a fix. On your Venu, go in to Settings > System > Display and change "During Activity" to Always On. This will then mean the Auto-Scroll option in your activity settings will be available again. It seems that the update unexpectedly changed the Display setting which then removed the Auto-Scroll option. Thankfully an easy fix and I am back up and running!
I would not call that a fix... Maybe a temporary workaround. The desired behaviour for the vast majority of users is as follows: have display turned off and when I raise my wrist, auto-scroll over data screens to show stats, put wrist back down and turn the screen off. What you have described as a fix means that my display will be always on and scrolling over available data screens even when I won't be looking at my watch. That will significantly reduce battery life for long activities, such as a 100+ km rides.
Garmin-ZacGarmin-AmberD can we get official statement on this problem? You guys can't tell me that desired functionality for autoscrolling is display always turned on. That will significantly reduce battery life for longer activities. Why would you do that?
Brilliant! Thanks so much for this - I had noticed it had stopped scrolling when I was exercising and it was really annoying, but I kept forgetting to go and reset it before I used it again! I figured it had just reset to a "no" default with an update, then I found it had gone as an option altogether. So happy to have it back :-)
