fever monitor
Once I was finally able to get this to upload to my watch and start monitoring it makes no sense what it's doing.  I mean I get the chart but it doesn't tell me from what baseline.  Are we to assume it's off a "normal" 98.6 or did it gauge MY "normal" 97.7 and go from there?
  • HI there! I went to the developers information page regarding this. I found this information, if it is helpful.
    How it works:
    Body temperature is measured with the temperature sensor of your watch once per day during the night. You will see the deviation from your normal body temperature (averaged over the last few days). This makes it easy to identify an abnormal rise or variation in temperature which can be a sign of a fever.
    I looked through the information provided from this developer and did not see anything regarding the baseline. Here is the link, I would contact the developer and ask the if they can clarify this for you!
    Fever Monitor
  • I understand the deviation.  What is the baseline?  Is it based off of my actual "normal" or what is considered "normal"?
  • This is something you will need to reach out to the developer of this app about.
