Hi just purchased new Sony headphones and they won’t connect with watch. Watch does not find headphones to pair despite following instructions ie Add device? Thanks
Moving thread to the venu forum.
Which headphone model do you have? Here is Garmin's compatibility list: Bluetooth® Headphone Compatibility for Garmin Watches That Feature Music
The only Sony BT headphones listed are the Sony MDR-XB50BS Extra Bass. Not that others can't work, but those are the ones that Garmin has tested.
Some other things to check
					i had the same issue while connection garmin venu to sony WH-XB900N.
After searching for a solution on the net for a while, this is how i got that working
1. Initialize the headphone to factory default. you can refer to the following link
helpguide.sony.net/.../TP0002050004.html
2. use the watch manual to connect to the headphone.
i believe your smart watch should be first device to pair with the headphone. Once successfully paired, you can switch the pairing back and forth with smart watch and any other device.
Hope that helps.
I also had issues connecting sony xb900n bt headphones. I came across the YouTube video above and followed the trouble shooting methods outlined in this video. It finally worked after unpairing from my phone turning off the headphones and then holding down the on button for 4 seconds until the headphones stated "pairing". Then when I had the watch scan for new headphones it finally seen them!
