Custom workouts are not supported on the Venu. Create the workout under a supported activity such as Run, Bike, Cardio. Make sure to Save the workout after you've finished creating. Once you've saved the…
What? .. I can't do Personalized Workouts because it's a Venu? A 300 euro sports watch that cannot create Training Times and Names, just because it is for Wellness ?? ..we are delusional !
..and…
Bingo! I deleted some pre-loaded workouts and now my custom one is showing up! I had to choose though like cardio/strength for it to work.
OK I found a fix. On your phone go to the workouts download them to your phone then there’s a little symbol in the upper right of another download then hit that one and then a message comes up with a checkmark says that it’s available I found I had to do both those steps to get it actually sent it to the watch and then of course you have to synchronize the watch then when I went to the activity on the watch and then I swiped up and slice it work out it showed up see if that works for you.
it is known as the Garmin Connect Bug.
It does not transfer Custom workouts, it also cannot do sections of the Cardio phases.
Custom workouts are not supported on the Venu. Create the workout under a supported activity such as Run, Bike, Cardio. Make sure to Save the workout after you've finished creating. Once you've saved the workout click the "send to device" prompt. Select the device and sync. Once that is complete you can find the workout on your watch under the category you created it within. I have had success doing this with my Venu.
I come from the Polar system and I can say that Garmin Connect Bug is a vomiting system, limited to running but not suitable for Professional Sport .... unfortunately my wife gave me a Garmin Venu that does not allow you to do basic personalized Cardio workouts, due to incompetence of the Garmin Connect Bug system. for example:
Try creating this workout at Cicuito:
-1 min Jumps with rope +20 seconds rest
-30 push-ups on arms + 30 sec rest x 3 times
-2 minutes, punching bag punches + 1 minute break x 3 times
-30 Squat Jump + 30 sec rest x 3 times
-2 minutes, kick the punching bag + 1 minute break x 3 times
-10 minutes to rest
Well of this workout, the Garmin Connect Bug, should return a simple Cardio Graph with the "sections" of the Phases "as happens in "Polar Flow" to determine the cardio condition between one phase and another (activity and rest) of the training. ..to then compare it to the next workout
Custom Workouts are "only" the addition of Times and Names to exercises therefore, it is not "Compatibility" but the incompetence (or commercial reasons) of the technicians working on the Garmin Connect Bug.
Understand that in the Garmin arena, the venu is considered a "health and wellness" device, where if you move into forerunners and fenix devices you move into the "running/multisport" arena. You'll find a forerunner or fenix will fit your needs.
..and to train I should tell my wife that she was wrong to give me a Venu but she should have taken a Fenix ?? Right, and what would be the motivation? the Fenix has the same sensors but is it dedicated to sport? ... absurd.
This is only incompetence of Garmin Connect Bug or rather for commercial reasons.
