Body battery Venu+Vivomove Luxe
I use Venu as prefered/main tracker and Vivomove Luxe as secondary. Body battery statistics in the app is shown just for main tracker. Only for Venu if that is main tracker, or for Vivomove Luxe if I make it prefered tarcker. If I switch from one to other as prefered trackers when I use each of them, get the grapf from both, but the grapf is is not correct. In this case the grapf looks like 2 separate grapfs put on each other with huge drop or up when I change the prefered tracker). During the switch the grapf comes to point where the same tracker previosly was used. For example:
I use venu from 00.00 to 8.00, body battery last result is 80. I put on Vivomove Luxe and make it prefered tracker and it the grapf shows 60. The same 60 which it was when I took off Luxe the day before. After using Vivomove Luxe till 17.00, the body battery goes from 60 to 30. Then I put on Venu and make it oprefered tracker, the body battery comes to some 50 (I would get the same number if I would not use Luxe at all, and the app just simply aproximately calculated that during not using Venu time the body battery would have dropped from 80 to 50).
So each watch tracks it's own body battery and app does not connect data from both trackers. App uses either one or other or shows both but not "connecting" the data.
I have seen that Garmin say that if you want to see Body Battery you have to have all watches with this feature. But having both watches with the feature does not work properly.
Anobody else with 2 trackers and having correct body battery data when switching from one tracker to another?
