I pulled out my Venu Sq to wear again, and since it had been a while I did a reset and then did the updates through Express. The body battery reset to a higher number, which I expected since I swapped devices, but the number from the Venu Sq isn't syncing in the app. The watch is in the 70s but the app is in the 20s from my other device. I set the Venu Sq as the preferred tracker and have restarted it.
Also, does the Stress level take time to adjust on a new device? It's significantly lower since I swapped. (I'm okay with that - I can pretend I'm relaxing ️)
