Current weather temperature WAY off
I’ve run across a new problem with the weather widget.  The current temperature (first screen) on my weather widget is way off.  For instance it currently shows its 36 when in reality its 45.  I synced and nothing changed.  The hourly and daily on the other hand does appear correct and shows 45 right now even though the first screen still shows 36 F.
    My problem is a little different then the one shown in the Venu forum.  Its like the first screen in the weather widget is getting its data from somewhere else.
    Ok, so when I first scrolled to my weather widget, it showed 52F, (which is close to correct) and then it switched right in front of me to 59.
    Iit switched from 52 to 59f on the first weather widget screen when I tapped on the weather widget.
    Here showing 52f hourly at 3pm, 4pm etc.  This is correct and what the first screen should display which it does briefly.
  • I caught it on video this time!  It shows 59 then automatically drops to 52. My finger gets in the way a little in the first one but the second one is even stranger temperature wise.  These two videos were taken within about 30 minutes of each other.
    Click here to play this video
    It starts out at 54f which is right, then jumps up to 61 in the first few seconds.
  • I contacted support this morning since no response in here.
    1. Remove the widget
    2. Do a soft reset by holding down the A button for 30 seconds or so (past the assistance screen) until it turns off.  Then turn it back on with A button.
    3. Add weather widget back in and sync to Garmin Connect.
    This fixed it for me I am happy to say.
