My Networks - Searching for Wi-Fi Network -Stuck Spinning
My Home Wi-Fi router is called "Chris-Router-2.4"
In the Garmin Connect Mobile (GCM) app I added the network to my device.
Garmin Devices > Venu SQ Music > General > Wi-Fi Networks > Add a Network
After I added the network I tested it.
Garmin Devices > Venu SQ Music > General > Wi-Fi Networks > Chris-Router-2.4 > Test Network Connection
a window pops up saying to test it press 'connect', I push connect and a new window pops up saying "Successfully Connected to "Chris-Router-2.4" and to push 'ok'.
At the same time my Venu SQ shows "connecting to Chris-Router-2.4" and then "Connection Successful"
------Everything seems good the network is added to my Garmin Venu SQ
On my Venu SQ, using the "Menu" button I selected:
Settings > Wi-Fi > My Networks
In this "My Networks" screen I see two choice:
Settings > Wi-Fi > My Networks > Add Network
Settings > Wi-Fi > My Networks > Chris-Router-2.4
--Now I have verified that I have set up my Venu SQ with my home Wi-Fi
Going up a level back to - Settings > Wi-Fi
I select:
Settings > Wi-Fi > Auto Upload (On)
Going up again, back to - Settings > Wi-Fi
I select:
Settings > Wi-Fi > Connect to Wi-Fi
The screen changes to a spinning window with (Searching for Wi-Fi Network),
--It gets stuck.  It does not move to 'transferring' or 'transfer complete'  (like on my other Garmin's)
When my Venu SQ is stuck spinning in this "Searching for Wi-Fi Network", I look at my phone and on the GCM app, and I see that the blue sync circle is spinning.
I want to load Spotify playlists, but the Venu SQ is not connecting with my home Wi-Fi.
Any troubleshooting suggestions?
