Body battery not updating after charging
I’ve noticed after charging my watch that the body battery doesn’t seem to update as it should.  For instance this morning it showed 30.  After I powered the watch off and back on it then showed 70!  Clearly a bug.
Is there a forum to report bugs by the way, or are these forums looked at Garmin?
  • I have same problem my fenix 6 stop measure stress after charging!
  • It’s mostly a user forum, though they watch it and respond when there is a common problem.  I just do a hard reset on mine every time after I charge to prevent this problem (hold A button down for about 10 seconds past any notifications until it powers off) then power it back on.
    You can go to support.garmin.com and start a chat session if you run into serious problems.
