I have two sets of Vector 3. On one set I usually get a L/R balance of approximately 48% / 52% so I decided to do a static torque test to see if there was a difference in the pedals.
The average results were L = 24.725 R = 25.03
As the mass being used was just over 15kg I am taking it that the R is more or less correct and would imply a mass of 15.0087Kg (G=9.81 and Crank = 170mm)
I decided to change the scale factor of the L pedal. I changed it to 25.03/24.725 = 1.0123.
If I do the static torque test again should I expect to see different torque results or is the scale factor only applied to calculate the power?
Nick
