Hi everyone,
I bought two Vector 3 dual sided power meters three months ago. They worked fine for a while but suddenly the wattage readings were lower for the same workout intensity. First I thought I was tired or overtrained but the difference was large, around 50 watts. On March 13th I did the 20' FTP test and I got 337 W. I did the same test today and despite being 5" faster, I got a wattage reading of 295 W. Both tests were at the same segment, a 5% hill, and wind and temperature were similar. Firmware is updated at 3.8 version and pedals are calibrated using a Garmin Edge 830 head unit on daily basis. You can see both activities here:
https://connect.garmin.com/modern/activity/6422799970
https://connect.garmin.com/modern/activity/6918090739
I've been searching on forums for some other users having the same problem as me but I couldn't find anything so I would appreciate some enlightenment.
Thank you very much.
