Hi,
my right pedal (Vector 3) suffers from really short battery life, see the timeline below. I swapped the batteries in the right pedal *only*, no problems with the left pedal.
I measured voltage levels with a calibrated voltmeter device.
I describe the timeline and my analysis bellow, the format is <date> -- <description>:
Battery 1:
- 23.2. -- new battery in the right pedal, Nexcell CR1/3N, 3V
- approx 3 indoor one hour sessions.
- 5.3. -- right pedal battery dead (1.81V, measured)
Battery 2: (with proper analysis)
- New couple of Varta V13GA/LR44:
- 6.3. -- new batteries in the right pedal, 3.15V, measured
- 6.3. -- 1 hour indoor ride, room with temperature 21 degrees C, connect.garmin.com/.../6385145395
- 7.3. -- 2.88V
- 7.3. -- 1.5 hour outside ride, temperature 8 degrees C, connect.garmin.com/.../6390936596
- 8.3. -- 2.75V, bike in a room with temperature 15 degrees C
- 10.3. -- 2.60V -- moved bike to a room with temperature 21 degrees C
- 10.3. -- 1 hour indoor ride, connect.garmin.com/.../6408691324
- 10.3. -- after the ride 2.64V
- 11.3. -- 2.72V -- I believe that voltage increase is due to higher temperature.
- 11.3. -- 45 minutes indoor ride, connect.garmin.com/.../6424400765
- 13.3. -- 2.57V
- 13.3. -- 40 minutes indoor ride, connect.garmin.com/.../6424400953
- 15.3. -- 2.36V, batteries dead
EDIT: I use 920XT as a head unit. It seems that edit destroyed links to the activites :-/
I do appreciate any help.
