1)
According the formula on the Garmin web page, the Torque Effectiveness is calculated as (((P+) + (P-))/(P+))*100. If I understand right, this sum of ((P+) + (P-)) means the total power or work applied to the pedal, and the P+ is the amount of the power applied effective in the relationship of the movement of the bike.
If it is supposed to be as is written above, than the relationship is probably not correct and should be replaced by ((P+)/((P+) + (P-)))*100.
2)
The other question is - if the Vectors 3 evaluate the effective force acting to the pedal compare to the total force. Because only the vector of the total force acting perpendicular to the crank arm is effective and causes movement of the bike, rest of the force is wasting of the energy.
3)
Do the Vectors 3 evaluate the pushing down also pulling up of the pedals to result the total power and the cycling dynamics? I suppose yes, but I did not find the clear information.
4)
What values of Torque Effectiveness is supposed to get for the unloaded pedal, when I am using Vectors 3 (dual system) in case of:
I am pedaling only with right foot, the left foot is out of the pedal
I am pedaling only with left foot, the right foot is out of the pedal
Testing my Vectors 3 I got different values for the unloaded pedals, I got for unloaded left food value of 99 and for unloaded right food I got 0. In both cases acts on the unloaded side only the self-weight of the pedal, probably the results should be the same...
Kind regards.
milos
