Pedals connected but not showing any ride data during or after. Using wahoo Bolt
I'm using the pedals to ride on zwift and also have them connected to my wahoo element bolt. The pedals are showing connected thru garmin app but its not showing any activity during and after rides like the pedal offset and standing or sitting etc.. it shows no activity on the garmin app.
Do I need to disconnect it from my wahoo bolt ? Can it only connect to 1 app at a time or is there something else I need to see the live data on garmin android app?? I don't see anything that says connect and when I check pedals they are connected just fine.
Thanks
  • I guess you need a garmin headunit in order to connect to the garmin connect app to show the data. If you import it from the wahoo element thru garmin manually you will be missing alot of the data. Hopefully they fix otherwise I might return for assioma duo. If anyone knows a workaround let me know please
  • I assume when you say they are connected through the Garmin app, you are referring to the Garmin Connect app on your phone?  This application does not handle any “live” ride data and the Vector 3 pedals do not store any ride information themselves.  With the Vector 3 pedals it would just be used to configure and update the firmware.
    In order to record the cycling dynamics (pedal offset, standing/sitting, etc.) you need a head unit that supports reading cycling dynamics.  Unfortunately, your Wahoo Element Bolt does not support this as far as I am aware.  Getting Assioma pedals would not change this since they also require a head unit that supports those metrics.  I suggest you let Wahoo know that you want this feature — they do listen as people complained about the Wahoo head units not supporting the Radar profile and they eventually added it.
