Hi, I have been using an EDGE 1030 and Vector 3 combo with 172.5 mm cranks for a long time. I cracked a crank. The LBS gave me loaner 170 mm cranks.
I noticed on last ride my wattage was off (I hadn’t realized the cranks were 170mm)
Ok, so I want to reset my crank length.
In the edge 1030 I can get to the sensor but when I press crank length it just blinks, I cannot edit it. I deleted the sensor and re-added the V3. Same thing. I cannot edit it
I am in Sensors ->The V3 -> Sensor Details -> Crank length. I click on Crank Length and it highlights but no edit screen.
So I tried in connect on my Iphone. I got the sensor, changed it to 170, backed out and back in - it’s 170. Great.
However, Then when I synch the Phone to the Edge, hoping it will set crank length on the edge the phone reverts to 172.5 and the edge remains 172.5.
I have removed sensors and re-added on both devices. The Edge simply won’t take 170 and seems to “overpower” the phone.
I haven’t factory reset the edge yet - is that the next step? Any other suggestions?
