Left pedal: Red LED is always on & not vector3 not discoverable
I just changed batteries after the winter and while the right pedal is working fine (blinking 3 times in 15s intervals) the left pedal is just SOLID RED. No blinking, nothing. as soon as the power connects the led is SOLID red. Does not matter if it's screwed into the crank or not.
I can't find the left pedal in connect or with my edge 820 (which worked last year). So.. what's up? Did the left pedal die over the winter, standing in a 21° room? After the whole firmware fiasko, the battery door and the battery drain that would be a fitting end... how long is the garmin warranty on those?
Thanks,
Klaus
