Hi all,
I have read different posts on how to look at the voltage to understand where your Vector 3 batteries are currently at. I have had the battery okay, and then battery low message before and then after a ride. I have a Mac, and downloaded FitFileExplorer from the App Store to analyze a fit file. My issue is that I cannot locate a fit file to analyze, where would these be stored? I did see another post about the files being stored underneath the Library/Application Support/Garmin.... etc, but I never was able to find the Garmin folder. I am stuck at this point.
Side issue, I had to reinstall the Garmin Express 6.5.1 software because as of a few days ago, as it no longer connects to Garmin's background service and will not even connect to my watch(I believe Garmin is aware of this and is working on a fix). Re-install did not fix this issue... Waiting on update from Garmin...
In the meantime any suggestions or advice would be greatly appreciated in regards to finding the fit files to analyze from my rides. Thank you!
