hi
After using the Vector 3 last 3 weeks only indoor i have taken the bike out for a ride today.Tempeture was around 2 graded Celsius on average and a minimum of 0 Celsius.The course i have done is one i do frequently and the power was low like 20-25 watts for the forst 45 minutes.i have zeroed the powermeter 10 min before the ride and once after 5 min.Power was low bu 20-30 watts in my opinion and it was also reacting slow when i cahenged the pace.after 30 -40!minutes i did a zero again.seems like it was reading only 10-12 watts after the last zero offset.So i check the battery voltage was like 2.6-2.7 .So the Question is was the battery voltage the cause or they weren t adapted to the temperature drift from indoors(16-18 degrees Celsiu)to outdoors 0-2 degrees?
