I've the problem with my left Vector 3 pedal that it no longer flashes anymore after I've changed my battery. It looks like it won't work anymore :(.... Does anyone of you had the same problem?
1. Check to see that the batteries did not inadvertently turn upside down as you installed the cap. 2. Try re-installing the old batteries to make sure that the new batteries are not dead (or use a suitable battery test meter on the new batteries, if you have one). 3. Make sure the metal battery contact cage in the cap did not move out of position or get damaged, and check that the contacts inside the battery compartment are clean and not damaged.
