Wahoo ELEMNT / BOLT Users - Able to replicate these issues?
Evening, forums:
For those who use a Wahoo head unit, I'm curious if you're able to replicate the following results when pairing your vector dual pedals w/ a Wahoo head unit:
- Pedal Smoothness displaying a '--' value for several seconds but never on the left side. For example: data will go from from '17/17' to 17/--'. Occurs everyone 2-3 minutes, for 3-5 seconds duration each occurrence. These dropouts do not show up on the fit file.
- PS and TE showing a positive value on the left pedal when only pedaling with the right leg. Screenshot attached showing this occurrence. A similar screenshot is attached showing data when pedaling with the left leg. This data looks normal.
- Data dropout when pedaling from a stopped position or from coasting to spinning cadence back up (screenshot attached showing dropout).
____________________________
Overall, my power data seems right. Can't tell if this is a Vector issue or Wahoo issue. Garmin customer service says they are unable to analyze Wahoo fit files while Wahoo reports the dropouts are a result of the power meter since they don't see any dropouts w/ heart and speed sensors.
For background:
- This is my third pair of Vector dual pedals. This set (responsible for the attached screenshots) came with the new pedal doors in late July. I've seen the '17/--' dropout on all 3 pairs. I didn't start testing left and right pedal drills until the third set.
- I'm familiar with the battery issues and have followed Garmin's suggested tips and service advice.
- I'm presently using the Varta LR44 batteries.
- I calibrate the pedals before each ride
- Pedal firmware is 3.5
- I use a Wahoo ELEMNT Bolt
- I use a Polar HR monitor via BLE
- I use a Wahoo speed sensor via ANT+
ciq.forums.garmin.com/.../1396655.png ciq.forums.garmin.com/.../1396656.png ciq.forums.garmin.com/.../1396657.png ciq.forums.garmin.com/.../1396658.png
