Had the same issue and don't want to buy a full set. I just ordered one from amazon will update this post when I see if it fits.
Any luck with the socket you purchased? If so can you please share a link to it?
I received the “
from Amazon. It works perfect for the Vector 3 pedal spindle nut.
Try searching for "thin wall" sockets. They exist and are designed for this type application.
I ground down a Craftsman 12mm 1/4-inch socket a bit on a bench grinder. Worked like a charm. Tip from guy at my local bike shop, Cycle Progression. P.S. I had a million 12mm sockets 3/8 and 1/4, deep and short, and not one of them worked. The grinding was the bomb tho.
I wanted to share that this worked for me. I bought a 12mm 1/4" drive deep socket from home depot and it fit fine without any grinding. my 3/8" drive sockets did not fit
