As I've been pondering some of the battery contact problems folks are having (me as well), it leads me to an interesting question. Is the problem just in the local electrical connections to the batteries? I've looked at how these are designed and it leaves me scratching my head a bit. I took the diagram that is provided by Garmin in their "How to rebuild the Vector 3 pedals" link and shifted around the components to try to understand the assembly relationships between the parts. I cut and pasted the photo of the axle into its correct location inside the pedal and the result seems striking. The final bearing surface is only about 15mm (or so) outboard of pedal center. That leaves a lot of cantilevered plastic (certainly composite filled plastic but plastic never-the-less) supporting the large pedaling forces onto the pedals. My pedals have developed "polished" spots in the stainless steel strike plates just under the outer and inner-most cross-point screws holding the plates to the tops of the pedals. This suggests a significant load applied well outboard of the outermost bearing support which could introduce flexing in the plastic pedal body.
Now, let's look at how power is delivered to the electronics of the pedal that are embedded inside the pedal axle. The end of the shaft has two small spring-loaded pins which contact a printed circuit board on the back of Part 4 which is screwed to the bearing retaining nut. These are not related to anything that you see when you're changing batteries; they're on the back side of the little printed circuit board that you see inside the pedal and which carries the center gold-plated battery fingers (negative battery terminal). It also has the two gold-plated pads that the outer legs of the battery carrier contact. If you stop and think about it, the pedal shaft is continuously turning relative to the pedal and the printed circuit board is tied to this shaft. That means that the entire battery carrier is spinning inside the pedal housing along with the shaft. The screw-in metal cap, however, is fixed to the pedals so the black plastic battery carrier needs to spin inside this metal cap! Seems okay at first but since the rider is also forcefully exerting against the pedals, if the unsupported plastic pedal body flexes as postulated above, this means that the battery carrier moves with respect to the center-of-rotation of the metal cap, potentially introducing all kinds of lateral forces. In a worst case, could the battery holder actually be forced into contact with the metal cap, causing drag and disrupting the battery contacts? You'll notice when you change the batteries that there is a lot of built-in mechanical "float" between the battery holder and the cap which would be needed to accommodate pedal deflections. However, if the center of rotation of the battery holder doesn't match that of the pedal during hard pedaling, there could be an inherent drag between the metal cap and the holder. There is a remarkably small amount of compliance in the positive battery contact arms which span the outermost surface of the outer battery (away from the bike) to the printed circuit board pads on Part 4. It seems this connection could be very susceptible to disruption.
Anyway, sorry for my rambling but it really struck me hard when I realized that the entire battery holder was fixed to the shaft, essentially causing it to spin relative to the plastic pedal housing and the metal end cap. You really don't think about this (or at least, I didn't) when replacing the batteries. This, combined by little support of the outboard portion of the pedals by the short pedal axle feels like a more significant design vulnerability than I had initially imagined. I'd be interested in your thoughts. ciq.forums.garmin.com/.../1338944.jpg
