Hello,
Curious how crank length is being set. I have multiple bikes, multiple Garmin devices. The devices are all newer devices with the "sensor pool" functions (520, 820, Fenix 3, FR935)
My understanding was that crank length is stored in the pedals, It's only set when I manually adjust the settings then the device sends the pedals the updated crank length.
Example: So when I move the pedals I only set the new crank length (172.5) in the first device I use, say my 520. Assuming the length gets set then next device I use, say the 820, reads the length from the pedal rather than setting it to the value from last time it was used (170).
Is this a correct understanding? Or do I need to set it on each device?
