Can I use a canyon grail cf with my Tacx Neo T2800? I heard a lot about passible issues with the disk brake and thru axle (already with 140mm discs). Now the canyon grail even has 160mm brakes, does the bike fit on the T2800?
You can use it with Neo but probably the rear brake need to be removed :) better to use bike with rim brakes on trainers, less problems.
Update: i found a guy who is using his Grail and Madone with 160s brake on his Neo without problem (i dont know the frame sizes), so maybe You will have luck too
Oh really? Where did you find this information with the grail and madone?
would be good to know, but I think frame size should not be an issue here.
Is there a difference between Neo2 and Neo2T?
write me pm and i share the guy's account to You.
The 2T is already supports the thru-axles natively, the 2 (and the 1) not . And the 2T has stronger magnets so its stronger @ lower speeds , the Neo1/2 has "slip" issue in certain cases if the disc speed was low but the power was higher. But the shape/size of the Neos are all the same (ok, except the very 1st gen Neo from oct 2015 till ~aug 2016, that has different plastic case but the Tacx had to redesign it because lots of TT bike couldnt work with it)
