BMI inaccurate - why? Lower weight = higher BMI with Index readings.
Nevermind. It's working so far as long as I manually change my height every day. I think it's changing my height but just removing my name and readding a new name to the scale with my proper height seems to get the correct BMI every day.
  • I had a similar problem, which was fixed by factory resetting the scale, correcting the values in Garmin Connect and then setting up the scale again with the correct values.
    Thanks for your response. I should have tried this.
    I had some other issues with the scale and had to return it anyways. Hopefully the issues are fixed because I'm still interested in owning one in the future if it'd work.
